03-19-2006, 10:25 PM
not finished yet, but off to a good start. - Ebay speaker cans - $100 - Polk db675 - $80 - Monster Clamps - $80 - MTX 4202 amp - $50 - Pioneer DEH-P480MP HU - $121
03-19-2006, 10:26 PM
03-19-2006, 10:27 PM
Malibu owners will know what those last two pics are about. Took about an hour to get those two speakers out.
03-19-2006, 10:39 PM
Dude, are those cans considered ballast? What do those bad boys weigh?
03-19-2006, 10:55 PM
Same cans I have, they are actually really light, fairly thin aluminum. Interesting to see them with Monster clamps.
03-20-2006, 4:02 PM
Why so long to remove those two?? Looks like you need a snap-on mini screwdriver about an inch tall.
03-20-2006, 4:05 PM
cause u need to take the windsheild off to get to them... i had my whole stereo stolen bout 2 yrs ago. 02 vlx. they took everything. amps, racks, batteries, steering wheel.subs, only thing they left.. were those 2 speakers.. lol.. grrrr
03-20-2006, 5:22 PM
It's hard to see that from the pic. Sorry to hear you got JACKED Skydog. Sounds like someone had a vlx that needed you're part's.
03-20-2006, 5:30 PM
Where did you get the speakers? Also from Ebay? Great price. Sorry about getting Jacked!!!!!!!!! Not cool.
03-20-2006, 9:14 PM
wiring check is this the correct way I need to wire these up ?
03-20-2006, 10:01 PM
That'll give you a 2 Ohm load on your amp..
03-20-2006, 10:16 PM
No, according to the MTX manual, that amp is not stable at 2ohms in bridged mode. You'll fry the amp. This would give you ~100 watts RMS total -- or 50 watts per speaker.. You can wire them normally (not bridged) but you're still going to get 50 watts per speaker.
03-20-2006, 10:24 PM
An hour to get the dash speakers out! damn it.. I want to pull my cheese ball sony xplods... maybe I'll leave them in for looks and clip the wires on the back.
03-20-2006, 10:28 PM
hmm, then how is it possible to get 100 watts x 2 into a 2 ohm load as the manual says you can. Would this require different a different speaker setup or what ?
03-20-2006, 10:34 PM
The amp is a two-channel amp. Your rating go as follow: Probly 50 x 2 @ 4 ohms 100 x 2 @ 2 ohms and Probly 200 X 1 at 4 ohm The amp is probly only 4 ohm stable in mono configuration. If you want your amp to see 2 ohms stereo then you need to add two more speakers. Clint- You could have removed the whole window as one and saved yourself a bunch of time, instead of turning the srewdriver about a 1/16 of a turn each time. How do I know this? I used to own an older Malibu with the speaker mounts like this. Then I found the eaiser way to do it.
03-20-2006, 10:38 PM
the idea of this scared the crap out of me, so 1/16 turns I went.
03-20-2006, 10:48 PM
The manual says "100 Watts x 2 into a 2 Ohm Load" That'd look like either of these: to maximize that amp, you may want to do this: (this way, each speaker will still see 50 Watts of power, but you'll have 4 speakers seeing 50 watts, verse just two seeing 50 Watts - so the volume should double..?..) (Message edited by yosquire on March 20, 2006)
03-20-2006, 10:56 PM
alright, well the plan is to eventually have 4 tower speakers so it is good to know that I can get the same out of this amp with 4 as it will be with the 2 for now. Thanks for the info. Gonna be a few weeks till I get a chance to finish everything up, rain this last weekend really slowed us down.
04-09-2006, 8:40 PM
04-09-2006, 8:40 PM
