Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 15, 2006
Old     (cvnrides)      Join Date: Feb 2006       03-07-2006, 6:14 PM Reply
I have a Kicker KX650.4 to power my tower speakers. The tower speakers are the Fusion combo set and run at 4ohms each set with one connection. If I run this amp in two channel bridged mode will I still get stereo effect?
Old    tclagggym            03-07-2006, 9:44 PM Reply
Yes, bridging them just gives you more power to them.
Old     (tbonus)      Join Date: Oct 2005       03-08-2006, 3:44 PM Reply
tim c: Bridging is combining the left and right channels to one channel and the end result is a single (mono) channel with twice the power.
Vince: There is a way around this though depending on the kx650.4 inputs. Does it have 2 or 4 channel inputs? If 4, it can be done, just run your left side to 1 & 2 and right side to 3 & 4 out of the head unit and make sure the amp settings are properly selected. If 2, your amp must have a setting to have #1 input feed #1 & 2 output and #2 input feed #3 & 4 out.
Old     (tbonus)      Join Date: Oct 2005       03-08-2006, 4:01 PM Reply
did some searching and came up with this: Your amp has an amp1 and amp 2. Run your head unit output left to amp 1 and run your head unit right side to amp 2. You will need 2 splitters for this.
Old     (cvnrides)      Join Date: Feb 2006       03-08-2006, 4:54 PM Reply
Thanks T I'll give it a try as soon as i get some splitters.
