2004 Wakesetter 23 LSV, front ballast drain pump keeps blowing the circuit breaker. Fill pumps all work great, rear drain pumps work great, but front drain pump will run for a minute or two then blow the breaker. If I wait a few minutes, reset it, it will then run another few minutes until it pops the breaker again. It has been doing this for a long time, so I pulled the drain pump apart to see if there was anyting stuck inside it. No, it is perfectly clean and normal inside the pump. Funny thing is this; I think the breaker that keeps blowing is the bilge breaker. So I looked at the bilge pump, but everything seems OK there too and it seems to work properly. I never have the bilge pump switch turned on when I am draining the ballast tanks, so I am confused why it would be blowing this breaker. Malibu must have wired the crain pumps to the same circuit as the bilge pumps. Any idea where to start?
