it is almost impossible due to the fact that when the two rollers, not boat wake, meet they will go from nothing to double the size instantly and is almost impossible to time. if you were able to time it thjen at the point of the cut into the wake after the foirst set you would be bounced beacuase the rollers almost pop out of the water you get get way off balanced. i have tried it but that means you must hit it at 90 degrees which is tight and also the rollers from the first turn interfered.
