Old     (jixxxer)      Join Date: Apr 2006       07-23-2009, 2:10 PM Reply
I have a fat seat in the rear of the boat and a 750 bag in the bow; When it comes time to drain the bow does fine cause the water is directed right to the drain fitting but the rear bag does fine until the water is more in the rear of the bag and the pump is just sucking air which doesnt like that. There is no connection in the rear of the bag to ease the problem, I was wondering how do the factory bags drain complete????
Old     (tampawake)      Join Date: Mar 2008       07-23-2009, 2:20 PM Reply
my center sack drains till its sucking water in my xstar. I pull the bag up so that it drains completely. I think that is just what you get with the bag type set up
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-23-2009, 2:22 PM Reply
You can add your own port if you can find a good spot to do it (lower on the sac, on one end so you concentrate the water there, whatever). Just buy a plastic thru-hull and some marine sealant. Cut a hole just big enough that the mushroom end will fit into the bag, squirt you sealant on the inside, then on the back of the thru-hull fitting, tighten her up.
Old     (cyclonecj)      Join Date: Jul 2001       07-23-2009, 6:41 PM Reply
I did exactly what Nacho describes on two fat seats, works great.
