Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 15, 2008
Old     (moosemac81)      Join Date: Oct 2008       10-23-2008, 9:48 PM Reply
Hey I am trying to change the oil on my 2006 mb b 52. Where does a guy hook the hose to run the boat on the trailor. The manual doesn't really say
Old     (wakesk8er2)      Join Date: Mar 2002       10-23-2008, 10:01 PM Reply
It depends how the boat is set up. Most newer boats have a fitting on the transom to hook the garden hose into. Some have that piece down inside the engine compartment.
If you don't have a place to hook the water hose into, you'll have to use a fake-a-lake, which is baically a plunger that wedges between the ground. The plunger part has a hose fitting on it to provide water to the intake while the boat is running.
There is also a way to do it by hooking it into the v-drive cooling line, but I've never used that method. Someone else should be able to chime in on that one.
Old     (moosemac81)      Join Date: Oct 2008       10-23-2008, 10:15 PM Reply
Ok sounds good the book said something about a fresh water flush is that where I would hook into?
Old     (04gravitygames)      Join Date: Jan 2006       10-24-2008, 7:51 AM Reply
look on the water inlet line to see if there is an inline flush kit.
if not then put a fake-a-lake on it and go with it.
