Need help doing my system.I want to get away from opening valves by hand if posible. I know the simmer will not let water by when not in use but how often do you have to change impellers?and does it stop the water all the time even when impeller is a bit worn?(the pump will be fed by a scoop intake while boat is moving)I don,t need the pump to reverse. Or should i just go to electric valves (a bit pricy). Any help would be very great.
