Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       08-11-2009, 6:43 PM Reply
Went out this weekend to ride with a couple friends and go about a mile from the launch. Stopped and water was glass. Put her in gear to move a bit closer to shore at idle, and there was a whole lot of not moving.
Stripped out the splines in my coupler. Pulled motor last night and picked up a coupler off eBay for cheap (I'm a poor boy, work full time school full time). Glass over stringer on starboard side is cracked in a few spots around motor mount and wood is soft. Port is much better, bolts tighten but not as tight as I'd like.
New stringers are not in the budget time or money wise for another year or two if I keep the boat long term. Tentative plan is to glass over the cracks. Then pour resin in the motor mount holes and use longer lag bolts to get into the wood at bottom that feels solid. Anyone ever do anything like this? If I can get another two seasons before doing stringers/floor/etc. I'd be happy.
Old     (loudsubz)      Join Date: Aug 2001       08-11-2009, 8:54 PM Reply
ummm how?
Old     (dizzyj)      Join Date: Jul 2003       08-12-2009, 12:38 PM Reply
I had some rot on my stringers where the moter moutns were. I cut out the glass, dug out the rot, used some sort of resin/rot-b-gone and injected into the good wood, then filled the hole with glass.
re-drilled the holes for the motor mounts and was good as new.
Old     (roverjohn)      Join Date: Dec 2007       08-12-2009, 1:00 PM Reply
I would back up the existing stringers with marine grade plywood and then liberally glass over everything. Replacing stringers only makes sense if you want to keep the boat light and, as a wake rider, you don't.
