put my brand new bindings (cwb zeus) on my brand new board (cwb prodigy platinum) and after a few falls the rear binding came off the board. I used the screws supplied with the bindings and they were tight. dethreaded probably half the depth of the inserts. anyone know the best way to repair?
Hey Josh, Thank you very much, I need to take a closer look at it, just haven't had the time. I think if I use longer screws it might work ok or I can use the other holes, if not I'll take you up on your offer. Once again thank you.
If the holes you were using are patially stripped they will have lost their ability to properly hold the binding bolts in. This can cause you irritation when they don't hold and possbily an injury.
If you resort to using other holes, you may not have the bindings set to where you really want them.
Brett, the same thing happened to me on my absolute platinum. i sent my board in to my local shop and they sent it to the company because they could not fix it and cwb sent me a brand new board still in the wraper so you could always give that a try...
