I've been doing a lot of winching lately with friends and one of the nuisances is getting in and out of your boots quickly.i just got an 08 slingshot recoil which has the 4x4 hole pattern but slingshots hole pattern is about a 1/4" wider. i custom drilled holes in the base plate to match the slingshot pattern and mounted burton mission bindings to the board. Using old linerless Lamar snowboard boots, i made some drain holes in the rubber outsole.
finally, i was able to test the idea and it worked like a charm. the boot/binding setup held me in just as well as any good wakeboard boot as i hit the box and rail we had setup. another advantage was my feet did not get torn up from the thorns, stick, rocks, etc. The only problem I'm running into is getting the boots dry, it took a good 2+ hours of running the hair dryer in them.
imo it would be quite easy for slingshot to modify their boots to have rubber outsoles that also dry quickly. it could be really appeal to the winchers and cable park riders.
some pics of the mod:
<img> left binding plate:
<img> right binding plate:
<img> if you want to see any more pics let me know
