I own a supra SSV, and the front bag drains a lot when surfing b/c of gravity. Anyone know of a plug you can buy that will fit in the thru-hull fitting for the drain? My other option is to re-run the drain line up around the bow and back to the drain (stern), or run the drain line up to the bow and add another thru hull fitting up there. I’ve heard of people adding a ball valve inline on the drain line, but wanted to see if anyone had a better idea?
