i have a quick question. What would you guys say is a better boat. an 89 supra? or a 99 Glastron. the supra is a direct drive, and the glastron is an I/O. what are your thoughts? opinions?
well what are the different models of boats that Supra made back then? if i saw them side by side then i might recognize the model. my dad and i just took a quick glance at the boat.
Seriously how can you even compare the two wakeboard boat vs fishing boat. Here is my 89 Supra I picked up three years ago for 9 Grand I added the tower and cleaned it up now look at.
Linden, Here is a link to the names and specs of the boats that Supra built in 89. http://www.nadaguides.com/default.aspx?LI=1-24-38-5692-0-0-0&l=1&w=24&p=38&f=5694&gc=MR>c=MR&m=1675&y=1989& ml=S The Conbrio and Comp are the two least desirable boats out of this list due to their freeboard. They are capable of producing a nicely shaped wake, but the low freeboard doesn't allow you to run much ballast from what I have seen. The Sunsport (Open bow)/Marauder (closed bow) hull is a proven hull and makes a great wake. The Saltare and Pirata are also pretty capable wake machines but take a lot of wake. You do need to check out the floor and stringers in the Supra as they are wood and may have some rot unless the boat was very well taken care of.
if a comp... take the glastron. they are pretty nice i/os. with proper weight can actually give a very rideable wake. if its like a sunsport...... take it and run!
