Old    S-bend= air rally 360            01-23-2002, 6:05 PM Reply
i have a hard time doing a 360 my board flys out from under me and instead of doing a 360 i go into a S-bend so i cant land it. (S-bend= air rally 360)any suggestions????
Old                01-23-2002, 7:53 PM Reply
i might be able to help you, but what kind of 3 are you trying to do? h/s or t/s, f/s or b/s, off or on axis??
Old    right off the wake            01-23-2002, 8:25 PM Reply
Sounds to me like you're just getting off-axis. Wait to start the rotation until the top of you're jump. When you start too low/soon(right off the wake) it usually throws you off axis. Try to wait just a little longer to start the rotation and that will probably fix that problem. Hope this helps...
Old                01-30-2002, 1:25 PM Reply
Kevin is right. Make sure you get the jump first, then start the rotation. I had the same problem and after a few falls knocking the breath out of me, I made sure I was off the wake first then did the rotation. Land it everytime I do right.
