Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 07, 2004
Old     (board4ce07)      Join Date: May 2004       05-18-2004, 4:53 PM Reply
how do you drive a triple up and how do you do one? pictures would be good too.
Old    lickmychode            05-18-2004, 5:30 PM Reply
a triple up is sim. to a double as far as riding. to drive: you cut the wheel as if you were going to spray some one then you swing around and cross at the swell you created by cutting the wheel.
Old     (that_nate_kid)      Join Date: Apr 2004       05-18-2004, 8:03 PM Reply
Here is the way i drive a triple. Make a 90 degree left turn, then a 90 degree right turn, so you are heading in the original direction. Make a wide turn to your right and look for the swell that came from the triangle you made from the two turns. Aim for just left of the swell. Reverse direction for goofy foot riders. Good luck
