Looks like it could work... I see a few potential problems. It will need a constant supply of water to run correctly. Depending on the mounting position you may run into some filling problems, especially while on the move. Its also not a reversable pump. Therfor you will need empty pumps. Look into Jabsco/ Simmer or other 2 way self priming pumps before you purchase. Don't get side tracked on gph(how much water it can move). Also when the exhaust faces up as in the attachment, this can cause increased problems. Have you ever attached a 1100 gph pump to a fat sac, turned it on, and it didn't empty? And when the pump is turned to the side it caught the water and it started to pump.. I see troubles. I think it would work much better pumping out 2 sacs instead of filling two. Buy reversable self priming pumps. Check out
www.wakeboardboats.com - the jabsco come with MC switches. They work well.
