likely the only (minor, fixable) problem anyone will have when mixing brands of boots and boards is that some have longer bolts/ shallower bolt holes than others making it difficult to screw the bolt all the way down and tight on the bindings
IF this issue arises you will need to do one of the following
a. grind the bolt down so it is shorter
b. use washers to take up the gap
c. buy different bolts
