Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old     (ridealready)      Join Date: Feb 2006       03-27-2008, 12:00 PM Reply
What are you all using to fill these? I heard straight 50 weight gear oil. Any tips and/or suggestions as we are about to drain and refill these? TIA
Old     (froese)      Join Date: Jun 2005       03-27-2008, 1:22 PM Reply
If you have a grease gun (which is what you need to pump into a Bearing Buddy) then any normal tube of grease that you can get at AutoZone or other such place will suffice. You can get cheap stuff or more expensive stuff, but it's all going to work.
If you don't have a grease gun, go get one... you'll see the kind of grease tube you need to buy.
Additionally, most places carry Marine Grease in the same tubes.
For a full on thread on the best grease to use, check out: http://www.offshoreonly.com/forums/archive/index.php/t-78770.html
Old     (montana_sanger)      Join Date: Nov 2007       03-27-2008, 2:00 PM Reply
When I hear bearing buddy I think of the old stand by. Try marine wheelbearing grease avail at your local dealer or walmart. Personally always had good luck with OMC/BMC brand.
If they are oil-bath hubs then you use the straight 50 wt some brands can vary.
Old     (ridealready)      Join Date: Feb 2006       03-28-2008, 11:11 AM Reply
They're definitely the oil bath type.
Old     (jhgsupra)      Join Date: Mar 2006       03-28-2008, 12:38 PM Reply
How do you get the oil in there? These are not the same as the grease gun type bearings.
Old     (meathead65)      Join Date: Sep 2006       03-28-2008, 12:43 PM Reply
You need to clarify...do you have Bearing Buddies or Oil Bath hubs?
Bearing buddies need a marine spec wheel bearing grease, and most oil bath hubs run straight 50 weight motor oil..not gear oil.
Old     (mars)      Join Date: Aug 2005       03-28-2008, 3:59 PM Reply
http://www.ufpnet.com/PDF/Trailer%20Buddy%20GOLD%20Axle%20Maintenance.pdf
