I need some info on a LY6 waterflow diagram.
My heater is not getting really hot like previous years on the 5.7 (monsoon340)engine.
I normally tap near or at the thermostat and return to a Y-Pipe.It gives plenty of heat but most important the LPG converter gets enough hot water to vaporize the liquid lpg.
Now i have the LY 6 and the 400 hp needs 2 converters/regulators with the current set-up(tapping from the drainhoses and return to Y-Pipe)it seems there is not enough flow.
The heater hose is 160 but the air comming out of the heater is not real hot.
would drilling a bigger hole inside the y-pipe help ?
or does someone has a better route?
here are some pics of the thermostat housing.
i could really need some advise.
