Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old     (joshuag)      Join Date: Feb 2007       07-08-2007, 11:00 PM Reply
Today i was on my lake which they a slowly draining to fix the dam when i was floating about 50yrds off shore when all of a sudden we feel a thump. Then we looked down and noticed that there was tons of rocks right beneith the boat. We quickly hopped out and got the boat away from the rocks but it bent the end of one of the blades. I didn't think anything happend so i continued my day at the lake for another couple hours. Could i have hurt my boat? I wasn't sure since the prop was slightly bent when it was spinning if it could have hurt some bearings or something. Also where should i get a replacement prop (from the dealer or online somewhere) and also how hard is it to replace. I have an 06 MC X15. Thanks alot and any comments would be appreciated.
Josh
Old     (mkperceptions)      Join Date: Jan 2007       07-08-2007, 11:05 PM Reply
Get your prop repaired. Cheaper and they do a awesome job
Old     (johns)      Join Date: Sep 2000       07-09-2007, 6:19 AM Reply
I dinged my original prop on my 02 SANTE so I bought a new one that was pitched a little better for the addtional ballast. I had the original prop repaired for a spare and they did a great job.
Old     (joshuag)      Join Date: Feb 2007       07-09-2007, 7:38 AM Reply
Where do you get your prop repaired? How much does that normally cost? Thanks alot.
Old     (bbeach)      Join Date: Jul 2002       07-09-2007, 7:50 AM Reply
Most prop shops can rework them for between $50-$75... Usually they work better, because they are more balanced...
Old     (wakebordr11)      Join Date: May 2001       07-09-2007, 9:57 AM Reply
depending how hard you hit and how bad it vibrated I'd check the shaft/strut for alignment to be sure those two pieces are not bent too badly...
