Try to loosen all the bolts where the bracket goes into the engine block and/or heads, if its a 2 piece bracket system this should help, if you have a spacer in there (short piece of round tube metal usually thick and a few inches long that a bolt goes thru before it goes thru alt.) you may have to grind it down just a hair to get everything in there (but you shouldnt have to) if all else fails get it lined up and use a little persuasuion with a pry bar or RUBBER mallet, don't whack it with an every day hammer, although I probably would after getting frustrated enough. Honestly it should go in pretty easy, make sure its not upside down or anything, and be sure all wires are hooked up correctly because if not once you give power it could fry your wiring
