Are you planning on buying at a shop, or on the net? You should be able to walk in to any shop and say you need a beginners setup, and they will look at you and your feet size and tell you what you need. If you are planning on buying from the net, check out boards from O'Brien like the Oasis, Edge, and the Clutch. Of course, all companies will make some beginner board/binding setups that will get the job done. Expect to pay approx 400 dollars, give or take.
