Old     (weskel)      Join Date: Jan 2007       05-30-2008, 11:30 AM Reply
Can you install a Stinger battery isolator and a perko switch together?
With the perko in the system I could still take both batteries to the off position.
I am assuming if it can be done, you would set it up to where when you put the perko in battery 1 position it would allow power to be drawn out of battery #1 when the engine is off and when the engine is running the isolator would kick in and allow power from both batteries.
Is this right?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-30-2008, 11:43 AM Reply
you don't need both. either will do
Old     (weskel)      Join Date: Jan 2007       05-30-2008, 11:45 AM Reply
If you just have a battery isolator, how do you physically disconnect the battery from the system when you store it?
Thanks
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-30-2008, 11:50 AM Reply
you shouldn't have to do that. I guess if you have a power leak somewhere I could see a need for both.
I would just put both batts on a trickle charge and not worry about it. If you're set on disconnecting, then yea, use both. not a common problem though.
Old     (kenteck)      Join Date: Jan 2005       05-30-2008, 1:48 PM Reply
you can hook it up like this, if you want:
