02-13-2005, 10:22 AM
Looking at a 2000-2002 Malibu v-drive, probably a 21 foot unless i find a 23 foot boat at a good deal and if the 23 ft will still give good performance. Is there a difference between the hulls on these boats, VLX vs. LSV. Also, how about different wakes... wakeboarding and surfing are what i do most.
02-13-2005, 11:22 AM
don't know about the hull difference, but I know that the VLX won't disappoint you. I've got a 2004 VLX. I think (don't hold it against me) that the only difference is the location of the engine with the v-drive. Call a malibu dealer, they'dknow.
02-13-2005, 12:50 PM
shooot! i should know this, but check out www.malibuboatowners.com they know everything.
02-13-2005, 5:25 PM
Not 100% sure but I believe the LSV has the diamond hull which is crap for wakeboarding. Make sure that it does not have the diamond hull. You will also want to make sure the VLX is not a diamond hull. I believe those years they are unless it is a wakesetter then it is the good hull. This past year we put 3500 pounds in my friends sunsetter direct drive with the diamond hull and the wake still blew.
02-13-2005, 6:32 PM
02-13-2005, 7:33 PM
what hull did they use on the '04 VLX?
02-13-2005, 9:18 PM
Do yourself a favor... Make sure you don't get the diamond hull. The wake hull is really good, and doesn't take a whole lot of weight to crank up a big wake. The Diamond hull on the other hand, does. Like Stan said, you can load the diamond hull with a lot of weight, and it still won't produce a respectable wake. We had the same problem this last summer. We had roughly 2200 lbs., plus the wedge, and the wake wasn't where it should have been... Plus, it had a wierd shape to it. The diamond hull is made for skiing, and not throwing a wake... It does a good job of it too, but I don't think it works sufficiently as a wakeboarding hull. -Blake
02-13-2005, 9:22 PM
The 04 VLX has the wake hull. Believe it, or not, but the only noticible difference is the outer 2-3" of the hull. Instead of angling up (with the flow of the v-hull), the diamond hull angles down, therefore causing the boat to rise as it moves through the water. It's a small difference, but it's definitely noticible when you're behind the boat. -Blake
02-13-2005, 9:30 PM
The '04 VLX had the SV23 Hull. The '05 Ride has the SV23 Hull. The '05 VLX has the V25 Hull The '05 WSLSV has the V25 Hull.
02-13-2005, 9:38 PM
I think there is a SV23 Diamond, and a SV23 Wake hull... The VLX has the wake hull, LSV has the diamond hull, but this is on the 2004 models, I don't know squat about the 05's.
02-13-2005, 9:57 PM
To clarify, All of the hulls I listed above are the Wake Hull.
02-13-2005, 10:21 PM
oh, damn! Troy busted me on that one.
02-14-2005, 2:56 PM
There are some un-informed opinions here unfortunately.... Both boats listed have sick wakes. They did make hull changes, but both the old and the new hulls are good. All the VLX's are sick. The LSV's are sick also. Main difference being the amount of weight to produce a huge wake. The LSV is bigger and takes more weight. I regularly ride behind an '01 LSV and a '04 LSV. They are both wicked. I actually prefer the '01. I think the wake is cleaner. Stay away from the Sunsetter and Sunsetter LSV. Not that the wake isn't useable, but it isn't on the same level ast he LSV. Pick which boat you want based on sizing and enjoy.
02-14-2005, 3:34 PM
the 04 and 05 ws LSVs have the same hull as on the 05 ws vlx. LSV is great if you bring out more people on a regular basis, then the wake is about the same as the vlx.
