If you are sure that it is not a simple fuse, electrical, switch, position indicator, battery problem, you can lift the drive by removing the hydralic arms from where they bolt to the stern drive (two bolts and about 10 minutes of time) and manually lift the drive and support it with a rope or strap. Basically, it's the first step in removing the whole stern drive.
