Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (ruste)      Join Date: Apr 2008       03-12-2009, 11:50 PM Reply
I have a 98 supersport/air nautique v-drive and i was thinking about adding a little more weight, it does not have factory ballast option, so right now just the weight of the ppl on board and i have two 250 lb sacs, one on each side of the engine. I wanted to get something taht will work great in the unused ski locker! what would work well here and about how much weight can i expect to gain? thanks alot in advance.
jeff
Old     (spencerwm)      Join Date: Feb 2009       03-13-2009, 8:09 AM Reply
From what I remember the Correct Craft Super Sport had a nice big ski locker. I would throw a Fly High Rear Seat Sac into the ski locker. It will maximize the weight you will be able to pack in there because the sac is soft. The bag's capacity is 580 lbs. I think you will get around 500 lbs. out of it.
Thanks,
Spencer@wakemakers.com
Old     (kamighazi)      Join Date: Nov 2008       03-13-2009, 8:48 AM Reply
http://www.wakeside.com/product/boat/ballast/ballast_bags/fly+high+pro+x+series+v-drive+sacs+set.do
Old     (sidekicknicholas)      Join Date: Mar 2007       03-13-2009, 9:14 AM Reply
Yup. on the supersport a Fat Seat Bottom will fit in like a glove.... when full there is NO extra room though, it fills it perfectly
It clearly isn't full in the picture but you can see how the width and length are perfect
Old     (rbalan)      Join Date: Jun 2005       03-13-2009, 11:44 AM Reply
I guess the extra 48 ounces is for truly dialing in the wake.
Don't forget to grind down all the screw tips coming from under the deck with a dremel or cutoff wheel. There was quite a few in mine.
Old     (spencerwm)      Join Date: Feb 2009       03-13-2009, 3:55 PM Reply
Fly High Pro X Series Rear Seat Sac
Size: 62" x 26" x 12"
Capacity: 580lbs.
Connections: 2 fill/vent - 1 drain
