Old     (face_smash)      Join Date: Aug 2004       04-30-2006, 10:05 AM Reply
Anyones boat been hard to start after the winter?? or will start on one occasion and then very stubben the next???? will it be bad or off fuel in the tank??? is this a common problem???
Old     (mattyboyr6)      Join Date: Jul 2003       04-30-2006, 10:40 AM Reply
If you've had your gas sitting in the tank without stabalizer in it for a few months it will make starting and running a little troublesome especialy if you have carbs. I'm sure its not good for fuel injected either. The old fuel if left in the carbs can gum up and block the jets.
You can either dump the gas on your bogenvias or start mixing in new good gas and probably some bottles of carb/fuel injector cleaner.
Old     (carcrz)      Join Date: Mar 2006       04-30-2006, 11:09 AM Reply
I'd agree w/ Mattato. I would also check the fuel filter & change if necessary.
