Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old     (wakemman910)      Join Date: Nov 2007       04-06-2008, 8:42 PM Reply
I just got my prop and was wondering if anyone else had a vibration in the steering or a kinda clunking feel it didnt do it with the old prop. i heard from the correct craft dealing somthing about shaving the rudder was wondering if anyone else heard of that.
its a 2000 xstar btw
Old     (ord27)      Join Date: Oct 2005       04-06-2008, 8:49 PM Reply
no problems with mine
Old     (wake_upppp)      Join Date: Nov 2003       04-06-2008, 8:58 PM Reply
The new prop may not be seated correctly. Far as I know shaving the rudder is to correct the pull on the steering wheel, not correct a vibration...
Old     (ironj32)      Join Date: Jan 2007       04-07-2008, 4:43 AM Reply
i have the same prop on the same boat and haven't experienced any vibration. the only difference you should notice is that you have a ton more torque and you'll be riding at a significantly higher rpm.
Old     (deltawake)      Join Date: Sep 2004       04-07-2008, 7:32 AM Reply
If it didn't do that before and you're using a brand new prop, Sparky is right. It's not seated properly. The square key rides in a channel. Usually the channel has a curved transition area. If the key rides up that curve, it will cause the prop not to seat evenly and hence the vibration. I'm pretty sure it doesn't have much to do with the rudder if the vibration wasn't there before.
Old     (xstarrider)      Join Date: Jun 2007       04-07-2008, 10:36 AM Reply
Same no vibration on mine......Like one said take it off and reseat the prop. Possibly didn't go all the way on.
Same boat BTW
Old     (noti_dad)      Join Date: Jul 2003       04-07-2008, 11:20 AM Reply
I have the 1234 (oposite turn) and love it. No vibration. I'll third the seating. Have it checked/check the fit.
Old     (wakemman910)      Join Date: Nov 2007       04-07-2008, 8:40 PM Reply
thanks for the help guys got it reseated and it works great
