Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 22, 2008
Old     (jpg)      Join Date: Jul 2007       08-28-2008, 11:33 AM Reply
LF shane bindings (response system)
The Problem is that one of the parts does not fit into the other (is not flush to other plate) creating a rocker effect on the binding when on board, which makes it impossible to crew down on board.
I have 2 pares of these bindings and all 4 of the plate systems are like this.
Any help would be great Thanks.
Old     (jpg)      Join Date: Jul 2007       08-28-2008, 11:53 AM Reply
Never mind i figure it out
Old     (romes)      Join Date: Sep 2006       08-28-2008, 11:56 AM Reply
did you switch the plates around?
Old     (kyle_neumann)      Join Date: Jun 2008       08-28-2008, 12:02 PM Reply
yea.. if u thought that it was wrong with all four of the one u owned.. then it probly isnt the binding thats doing something wrong..
Old     (caseman1322)      Join Date: Sep 2007       08-28-2008, 12:48 PM Reply
the new 08 Lf plates are made like that on purpose so when you screw it on all the way it actually bends the pieces flat so it's tighter on the board and makes it more responsive. The only problem is that it really is pretty much impossible to screw them on by hand. To get them as tight as they're supposed to be you need a drill. they don't explain that in the instructions but the dealers are supposed to tell you when you buy them
Old     (robertr720)      Join Date: Aug 2007       08-28-2008, 1:19 PM Reply
you need to put each screw in just a bit then tighten them all the way to get everything to set flush. When you do that the boots will rock side to side on most boards, but once you mount the boots to the board they will lock down. I would have said that maybe you have a defective pair, but since you said that they all do it, it leaves me to belive that it may be user error. I am not trying to sound like an a-hole but I have put well over 2 dozen of those bindings and never had a problem. I have put them on all sorts of boards.
