Craig, I've found that you have to ease into your cruising speed. If you blow past the desired speed, it will overcompensate getting back down to cruise speed. If I have mine set at 21MPH, I will start letting off at around 18MPH and ease into 21MPH. Also, when I first installed it, I had to put a second spring on the throttle linkage. This made quite a difference in how fast the boat de-accelerated. Hope that helps.
