Old     (sid7)      Join Date: Mar 2003       04-29-2003, 12:55 PM Reply
What is the best thing to use to get the registration stickers off of a boat? the person who owned the boat before me did a really poor job of putting them on and i want to take them off an get somemore.
Old     (jeffr)      Join Date: May 2002       04-29-2003, 12:59 PM Reply
Heat gun.
Old    swass            04-29-2003, 1:05 PM Reply
Your fingernail and Goof Off.
Old     (timmy)      Join Date: Jul 2001       04-29-2003, 1:12 PM Reply
I second the goof off. I used it a little over a week ago taking my reg off, as i recently moved to FL.
Old    midwest_boater            04-29-2003, 1:15 PM Reply
Use "Cut-Thru" from Certified. Just watch as the stickers slide off without hurting anything else.
Old     (sid7)      Join Date: Mar 2003       04-29-2003, 1:24 PM Reply
where are you guys getting good off and Cut thru at?
Old    swass            04-29-2003, 1:26 PM Reply
Pep Boys, CarQuest, AutoZone, etc.
I've never heard of Cut-Thru.
Old    leggester            04-29-2003, 1:35 PM Reply
WD40, Lighter Fluid, Acetone... ...
Old    swass            04-29-2003, 1:38 PM Reply
Yep...you don't need to spend the money on Goof Off. Any solvent you have layin' around will work too (e.g., paint thinner, toluene, MEK, gas, etc.).
Old     (sid7)      Join Date: Mar 2003       04-29-2003, 1:38 PM Reply
will the wd40 or lighter fluid hurt the gelcoat or anything??
Old    swass            04-29-2003, 1:41 PM Reply
Nope. Products like Goof Off are solvent-based too.
(Message edited by swass on April 29, 2003)
Old     (rmcronin)      Join Date: Aug 2002       04-29-2003, 6:10 PM Reply
mineral spirits or paint thinner work best, also work on old traction, anything involving glue. Won't hurt gelcoat, scrape excess glue off with a credit card.
Old     (monstertower)      Join Date: Mar 2003       04-30-2003, 7:06 PM Reply
Use a Daggone Shotgun ! It's Georgia Thang!!!
I use a razor blade but you have to be VERY careful or your chip the gelcoat. Solvent based sounds much better.
Old    ckabe            05-11-2003, 1:59 PM Reply
There is a 3-M product I've used in the past that worked great. I don't remember what it is called, but it is basically a large disc shaped eraser on a drill chuck. It is mounted on a drill and it peals the decals and glue off and leaves a pretty clean and smooth surface. I tried most of the other methods and I thought this was the fastest, safest way.
Old     (colorider)      Join Date: Jun 2001       05-11-2003, 8:00 PM Reply
I just used a blow dryer on them and they peeled right off. Just warm up the stickers and peel.
