Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through October 06, 2008
Old     (nauti4life)      Join Date: Sep 2008       09-22-2008, 5:03 PM Reply
Just wondering what your RPM is at surfing speeds?
Old     (05mobiuslsv)      Join Date: Apr 2006       09-22-2008, 5:41 PM Reply
With ACME 1235 prop and monsoon 340 I'm running 2500-2700 rmp at 10.6 mph.
Old     (spolk69)      Join Date: Aug 2008       09-22-2008, 7:06 PM Reply
09 tige 24 rz4 with pcm 409 hp ,i am pulling 2200-2300 rpm's with 1500 lbs ballast and 4 people @ 10.5 mph with stock prop...
Old     (mikeski)      Join Date: Aug 2003       09-22-2008, 11:44 PM Reply
depends on your prop
I have a Acme 536, turns about 2500 RPMs at about 10 MPH
Old     (wakemikey)      Join Date: Mar 2008       09-23-2008, 3:15 PM Reply
When I am surfing behind me 87 SunSport with a 13 x 12 prop the RPM's hover around 2000 at 13.5mph. The engine really doesn't like it and sputters and has a few blowbacks. We have corrected the timing but not yet rebuilt the carb. I was thinking that a power prop 13 x 10 would rev it up to about 2500 where it runs much better. Any thoughts? Love the surfin!
Old     (luchog)      Join Date: Jun 2002       09-23-2008, 7:25 PM Reply
with a 13x10 you wont get much top speed and will surely over rev the thing, imagine getting like 3800rpms at 20mph, can you spell gas milleage?
Old     (clubmyke)      Join Date: Aug 2004       09-23-2008, 8:30 PM Reply
depends.... i run pp in rpm mode for surfing- alot depends on weight and peeps..
average 2750 with a acme 1234 at 12mph (avg)
Old     (wotan)      Join Date: Jul 2008       09-24-2008, 8:27 AM Reply
Interesting.... on my 87 Saltare I'm running about 3200rpms @ ~10mph. This is with 2000lbs in it, though. Do I need have my prop repitched next time it goes in? Not sure what it's at now.
Old     (wakemikey)      Join Date: Mar 2008       09-24-2008, 1:14 PM Reply
A power or wakeboard prop should raise the RPM's into the engine's peak power zone. I don't WANT any high top end. Changing to a 10 pitch prop should not raise my rpm more than 500 at the most.
wakeboarding with 1500lbs at 23mph only runs 2500rpm also not quite fast enough rpm for good power pull.
Old     (luchog)      Join Date: Jun 2002       09-25-2008, 6:52 AM Reply
Acme has the 13x11.5 new props, 542 and 543 I think, those are the supposed power props.
Old     (bmartin)      Join Date: Jan 2007       09-25-2008, 8:27 AM Reply
2250-2500 RPMs, 8-10MPH.
Wow 3200RPMS sounds really high. I do not turn that many going 22MPH with 2000lbs.
Old     (wakemikey)      Join Date: Mar 2008       09-25-2008, 3:46 PM Reply
OJ recommended me to use their newest prop which was 13.25 x 10. $425
Old     (wotan)      Join Date: Jul 2008       09-26-2008, 8:29 AM Reply
Right now I'm running a 13x13 and my spare prop is a 14x14.... this is in a Supra Saltare.... what SHOULD I be running?
Old     (wakemikey)      Join Date: Mar 2008       09-26-2008, 3:10 PM Reply
13x 13 is the stock slalom prop. Mine also came with a 13x12. OJ recommends the 13x10 for us.
If you use a 13" diam you prolly can't use a 14" diam. But a 13x14would be even worse!
