Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (kstrongsyj)      Join Date: Sep 2006       08-09-2008, 4:55 PM Reply
I know, Probably a completely rookie question...
In changing the water impeller on an 02 Sanger V210. It is in the external "Seawater Pump" as the manual calls it. Last weekend the pump froze up completely. In taking it apart, the impeller looks fine, but it was definitely the impeller that was binding.
So my stupid question is....should it be greased or something? Allowing the blades to spin smoother within the housing?
Old     (sangerlover)      Join Date: Sep 2005       08-09-2008, 5:16 PM Reply
The pump housing is shot. Lots of $ to replace. I use dish soap to push the impeller into the pump.
Old     (treycleaton)      Join Date: Mar 2005       08-09-2008, 6:01 PM Reply
What indicates the pump froze up completely? Is the serpentine belt rotating without spinning the pump wheel or something? If its a Merc, you can buy a plastic Jabsco replacement for around $70. They also sell a brass housing that is big $. I put a coating of vaseline in the housing. www.skidim.com
Old     (kstrongsyj)      Join Date: Sep 2006       08-09-2008, 9:38 PM Reply
Here is a link to pics, etc. It is all put back together now to test in the morning...
http://forums.wakeboarder.com/viewtopic.php?p=1099180#1099180
Old     (trdon)      Join Date: Sep 2007       08-10-2008, 9:12 PM Reply
cosmocat, dont use vaseline, use something water soluable like soap. Vaseline (petrolium products) and rubber dont mix too well.
Old     (lovin_the_wake)      Join Date: Jul 2007       08-10-2008, 9:33 PM Reply
I spray mine with silicone spray twice a year when I winterize and dewinterize just because for some reason I think it should be done I don't know if it even makes the slightest bit of difference but I do it anyway
