As the cable comes off the back of the motor and is routed to the front of the motor, it passes thru a bracket with an adjustment on the top of the bracket and one on the bottom. Does anyone know if it matters which adjustment you use to take out the slack. PP is searching right now and will not hold. This has happened before and there is no sense towing the boat to the dealer for a simple adjustment. Thanks in advance.
Not sure if I am in the ball game with this, but, when that happened to me I had to simply turn the perfect pass module to wind the cable back. It is on the motor. Beyond that I would have to see it again.
deltahoosier
(firemedic)Join Date: Jul 2006
06-04-2007, 8:35 AM
