Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old    Slingshot            06-19-2009, 10:11 AM Reply
My buddy has a 2001 SAN with Perfect Pass Pro on it. How do you fine tune it? The speed is not right and when you floor the boat to get on plane it goes WWWWWAY to fast then slows down too much, then goes way to fast again...I just drive it without using the PP. How do I adjust it to make it work right?
Old     (bmartin)      Join Date: Jan 2007       06-19-2009, 10:24 AM Reply
Some of this sounds like how you are throttling it at start. As you get close to the set speed when getting on plane, start backing off the throttle manually a little so that you do not overshoot the speed. If you over shoot it too much, it will over correct, but eventually it should get dialed in.
If this is not the problem, you can also adjust the settings on how fast the PP computer adjusts speed and if you call PP they will help you out. This is one company that has awesome customer support.
Old     (mikeski)      Join Date: Aug 2003       06-19-2009, 10:54 PM Reply
Don't leave it floored. Just take off normally as if you don't even have perfect pass, then just overshoot the desired speed by only 1 or 2 mph. The PP takeover should be unnoticable.
Old     (wake26)      Join Date: Mar 2009       06-20-2009, 5:58 AM Reply
I had the same problem talked to PP they told me that I could have a weak throttle return spring and they also sent me an update to download on to my PP. went out last night with out the update but with a new spring and it seemed to help a bunch. Atthelake is right PP has been very helpful great company.
