Old     (espritv8)      Join Date: Dec 2009       04-23-2011, 7:00 AM Reply
Hi,
Last season I had to replace my impeller on one of my factory hard tank ballast pumps. They are Jabscos', and replaced with a jabsco impeller.
I compared the original impeller and the new one, and they looked exactly he same.
Changing them was pretty easy, just drop the new one in and spread the supplied lube evenly on the impeller.
But since then, that pump works slowly, and I can hear the motor run harder and it get stuck in fill or empty position. I have to play back and forth with the switch and it would eventually change position.
Anybody with the same problem? How to solve this?
If it is a lubrication problem, wich one is recommended?
Thanks
Old     (fman)      Join Date: Nov 2008       04-23-2011, 9:34 PM Reply
If you need to replace it, wakemakers has Johnson pumps on sale for $159 right now. They will replace the JABSCOs and they are a little bit faster for fill times.
Old     (espritv8)      Join Date: Dec 2009       04-24-2011, 8:11 PM Reply
I think the pumps are still okay. I wonder if this is a common problem that is an easy fix. Is there any maintenance or these pumps (grease or else) ?
Old     (spencerwm)      Join Date: Feb 2009       04-24-2011, 9:50 PM Reply
What color are your impellers? If you don't have green you may try them and I bet the problem is solved. I have also seen people polish the inside of the pumps.
Old     (espritv8)      Join Date: Dec 2009       04-25-2011, 7:14 PM Reply
No i ordered standard black impellers, I might try them. If i put silicone or another lubricant on it, will it help?
Old     (spencerwm)      Join Date: Feb 2009       04-26-2011, 9:07 AM Reply
Don't use any lubricants as you don't know what they will do the impeller. The pumps are water lubricated and shouldn't need anything else. The black impellers are really stiff which is why Jabsco has gone away from them in the new ballast puppy pumps. Go green. It's so hot right now. Hopefully you get them rocking before the season is in full swing.
Old     (espritv8)      Join Date: Dec 2009       04-26-2011, 3:43 PM Reply
OK, I'll trade my block ones. What's better, getting the green one or the blue globes?
