Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 01, 2005
Old     (rem_pss308)      Join Date: Mar 2004       03-01-2005, 5:35 AM Reply
Anyone on here using the Acme # 543 prop. It is 13 X 11.5.
Jim at acme recommended this one when using a lot of ballast.
With out a lot of ballast he recommended acme #541 13 X 12
I am just curious of the difference in rpms, and top end speed.
Old    natter            03-01-2005, 12:25 PM Reply
I dont have the same prop but this might help. I was using an acme prop 13.5 x 17.5 and changed to a 13.5 x 16 to help the hole shot for extra wieght in the boat. It took about 3 to 4 mph off at the top end. And the rpms run a little bit higher when your cruising around. But it was definitely worth it if your running alot of extra wieght.
Old     (davidbouvier)      Join Date: Aug 2002       03-01-2005, 5:52 PM Reply
i changed my stock 13.5 x 17.5 to a high altitude
prop. can't remember the number though. well worth it. the hole shot is much better. speed while turning back around stays consistent. top end speed drop like 7 mph. but, oh well, cna't have both.
Old     (phaeton)      Join Date: Feb 2002       03-01-2005, 6:09 PM Reply
Mike I ran that prop on my last boat. Switched from an OJ four blade 13 X 13. The Acme runs circles around that prop. Holds speed so much better and really helped the hole shot.
Old     (boarditup)      Join Date: Jan 2004       03-01-2005, 6:12 PM Reply
I have sold a lot of the 543 props and never had a disappointed customer. Trust Acme to size you up - they have performed a lot of testing to give the advice they do. It is not a guess - their advice is based on real research under real conditions.
www.boarditup.com
Old     (magic)      Join Date: Mar 2002       03-01-2005, 7:13 PM Reply
Mike, I run that prop on my Cal-Air (13x11.5 3 blade Acme)
The OJ 13x13 4 blade that came with the boat is no where as nice as the Acme for hole shot and speed holding on my boat. I have close to 1500#s of ballast in there and the Acme is much better with that weight.
