The toe, which is likely causing your wierd wear issues, is not adjustable. The only thing you can change (short of bending the axle) is the angle of the axle. If it's not aligned right the boat will "dog track" behind your vehicle, but it wont cause wierd tire wear. You can, however, replace your axle with a new one. They're readily available and could cure your wear issues.
