Old     (typhoon)      Join Date: Jul 2001       07-09-2006, 7:39 PM Reply
do most people use a scoop type strainer or a mushroom type for the thru-hull water pickup for ballast. i will be using a reversible pump so I do not think the scoop will speed things up any...suggestions?
Old     (stevev210)      Join Date: Feb 2005       07-09-2006, 8:00 PM Reply
I used a 1" thru-hull scoop when I did my system on my sanger. I use 2 jabsco pumps and 1" line for the whole system, very fast fill and drain times.
Old    d_fresh            07-10-2006, 3:50 AM Reply
Mushroom! Only aerator type pumps need the scoop to help with priming.
Old     (fbroen)      Join Date: Apr 2002       07-10-2006, 6:29 AM Reply
If you care about filling while at speed, you may want to consider a scoop even with a reversible pump. The mushrooms can be a bit 'bubbly' and take in a mix of air and water which will slow filling, at least on our x2.
