Patrick. if you go with Ronix...get the 08 not 07. I had a lot of problems with my 07 Cells, laces breaking out of the widget pull handle, the plate started to warp causing heel toe lift and finally the inserts would pull out...and they are not suppose to. Plus heat molded only last for half the season and you have to get them reheated. I had my cells replaced with 08's..so far they appear more durable. And Ronix said they had huge improvements. Now with that all said. I do own the new Murray 08 boots and have the 140. I have only been out a couple times. But I am loving the weight difference. These boots are WAY lighter thatn my Cells. I am really digging the new Murray's. I think you will too. BTW the Cells and the One boots are the same in weight and pretty much design and materials. I hope this helps. If you are looking at Murray's 08 boot vs. the 07 Ronix One boot...definitely get the Murrays. If you are comparing the 08 Murray to the 08 Ronix One boot...I am still leaning to the Murray for weight reduction. But quality...might be equal. Really dont know if the quality is better for Ronix in 08 until I ride these replacements they sent me. I hope this helps.
