I made the simplist slider two years ago. It is rather portable and has more than one use as i built it from a banana tube, pvc and some straps and ratchets. i drilled elongated holes for the straps to go through the sides of the pvc and tightened around belly of tube. I also used cinder blocks to weigh one end of the pipes down into the water and i used an anchor for the front too.
