Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 09, 2007
Old     (brttkrz)      Join Date: Aug 2005       02-05-2007, 10:36 AM Reply
I'm looking into installing PP on my friends 1990 Rinker 206 with a 350 magnum mercruiser. Does anyone know if it will work on a boat this old or have any experience installing it on something like this.
Old     (cyclonecj)      Join Date: Jul 2001       02-05-2007, 10:42 AM Reply
it should work fine. It's carbureted, right? see the website for pics of a carb install.
Old     (jarrod)      Join Date: May 2003       02-05-2007, 10:51 AM Reply
Just because it will install doesn't mean it will work.
Call perfect pass and ask them. The water must be undisturbed before it hits the paddlewheel. A lot of boats (even wakeboats) have trouble because of hull shapes, fins, etc...
Old     (sinkoumn)      Join Date: Jan 2007       02-05-2007, 10:53 AM Reply
I installed PP on my old boat which was a 1984 Nordic Crestliner that had a V6 185 Mercruiser, worked like a charm.
Old     (woreout)      Join Date: Aug 2006       02-05-2007, 11:00 AM Reply
Isnt perfect past the same as a great childhood?
Old     (jarrod)      Join Date: May 2003       02-05-2007, 11:30 AM Reply
I installed PP on a 2001 Wakesetter 23LSV as instructed by PP support and it did not work like a charm. The hull is a known problem for PP.
Old     (brttkrz)      Join Date: Aug 2005       02-05-2007, 7:33 PM Reply
Yes it is carbureted. It looks like it should work according to the pictures on the website. Where is a good spot to put the paddle wheel on the I/O. The site says 10 inches in front of the engine. Do they mean 10 inches in front of the lower unit or in front of the actual engine? Has anyone had problems with the paddlewheel on an I/O?
Old     (towboat_222)      Join Date: Feb 2007       02-07-2007, 1:11 PM Reply
Just whatch out for the lifting strakes. Will mess it up big time.
Old     (jon43)      Join Date: Aug 2003       02-07-2007, 7:26 PM Reply
I had it on a 1988 barrette sport i/o carb it worked great
Old     (dedicatedwse)      Join Date: Apr 2006       02-07-2007, 8:51 PM Reply
I had a 21' Wellcraft I/O and installed perfect pass. It had a 5.7L V-8 vortec (carbureted). Lots of power for the size and weight of the boat (the dry weight was about 2700 lbs).
I never could get my perfect pass dialed in speed control mode. BUT it worked GREAT when I ran it in RPM mode and was worth every penny!!! Riding behind it with different drivers became a breeze.
