12-09-2008, 3:45 PM
12-09-2008, 4:02 PM
Wow, WANT!! I got a DHM and hate my stock jack. Not to mention that for some reason if my trailer is level, the boat is sitting so that any water left in the bilge stays in the boat and does not drain out, so I have to pull some fancy maneuvers with blocks and a bottle jack to drain the hull properly. Nice find, I may have to upgrade.
12-09-2008, 6:17 PM
thats awesome, but do you really think that tiny piece of plastic, or "brake", will really stop a 5000 lb boat and trailer from rolling away?
12-09-2008, 6:50 PM
It doesn't really have to stop the boat.... just keep it stopped. Big difference. Obviously if you park on a hill, your gonna need wheel chocks. But my driveway has a slight incline to the side & I'd bet this would keep it there till I chocked the wheels.
12-09-2008, 7:54 PM
These things are legit. I actually work at the company HQ for West Marine. They had them at our sample sale for $30 bucks.
12-09-2008, 8:18 PM
VLX Envy hook me up.....
12-09-2008, 8:35 PM
I want one too. If I'm understanding correctly, because the mounting point is adjustable... I could unhook the trailer without first having to back onto ramps as I do now...!
12-09-2008, 9:31 PM
Cal Im not sure I understand what your asking. Im guessing your tailer jack doesn't extend all the way allowing your trailer to come off the tow ball and you have to put a block under the trailer jack wheel? If you look at the 2nd and 4th picture. You notice a grove in th eback side of the jack. The mount has a alan head bolt that you can loosen and move the mount either up or down. This is somthing that is done once. You adjust the amount of jack that folds down. This way you can have it set so the jack dosen't have to extend very much. I guess the only down side to adjusting it way down is that if you ever disconnect on un even surfaces (example) the edge of your driveway where the toung of the trailer is close to the ground you wont be able to un fold your jack. You would need to re adjust it back up.
12-09-2008, 9:33 PM
If you have the chance to get one of these for $30 I say swoop it up. Btw this thing must weigh 30 LBS.
12-09-2008, 9:37 PM
Sorry for my jibberish... (and yes, you interpreted correctly): when I unhook the trailer in the garage, the tongue is too close to the ground. When trying to pivot the jack into place, it bottoms-out before it hits the locking pin. Basically, I have to back onto the ramps to get the rear-end of the truck up higher, so that there is enough clearance to lower the jack. Sounds like this could help, so long as it's not so far towards the ball that I can't get the trailer unhooked on level surfaces. I think I should be fine. This may be on my Christmas list... (Message edited by phenom_1819 on December 09, 2008)
12-09-2008, 9:49 PM
Cal Yup: This jack can be adjusted to fix your problem.
12-10-2008, 5:59 AM
I think from what I've seen these come standard on 09' MC trailers.
12-10-2008, 6:14 AM
yep. its on the 09 mc trailers.
12-10-2008, 8:45 AM
I'd be down for one of those I hate it when my jack is fully extended and looks like its gonna buckle.
12-10-2008, 11:07 AM
I ordered one for my trailer and came to find out that the hole pattern will not fit around my trailer. Has anyone had this problem with one? I am hoping that they make a different one for next year cause I need one badly.
12-10-2008, 11:10 AM
It weights 21.450 pounds and I have pretty accurate info if you read my above post.
12-10-2008, 11:35 AM
Hey can you get another one for $30. I would take another one in a second for the pontoon boat.
12-10-2008, 12:25 PM
Thats the jack that came on my 09 MasterCraft trailer, and its ROCK SOLID. I never really trusted the old ones especially when pushing the tongue around. I always feared it would break like a double barrel shotgun and land on my toes.
12-10-2008, 12:57 PM
So Envy you gonna help some fellow WW members out on this one? Looks like there is alot of interest.
12-10-2008, 1:12 PM
I'm in for $30 ... anyone know if it will fit on a 2004 MC trailer with modification?
12-10-2008, 1:18 PM
I'm in for $30 also...
12-10-2008, 2:20 PM
X3 wheeeeeeeeeeeeeeee!!!!!!!!
12-10-2008, 3:19 PM
Uh slow down guys. I have access to ONE and ONE alone. Nu Bu is on the clock. PM was sent. I said "they had" them. Please do not jump the gun here. (Message edited by cavlxenvy on December 10, 2008)
12-10-2008, 3:49 PM
Hit you back Envy..
12-10-2008, 4:22 PM
what i don't get is, i've heard this won't fit the MC trailers 00-08 because they had something welded on for the old atwood jacks, but then i look at grant's pics and it looks really similar to my setup. help me out here i'm a little slow. do i have to remove what's on there now and weld something back on? i also read that the older atwood jacks are disco'd.
12-10-2008, 4:35 PM
Bruce: The new Fulton F2 jack will bolt on. It comes with "U" bolts. These will clamp around your trailer frame and bolt to the jack. The jack comes with 2 diffrent sizes. You should have no problem bolting it on. My trailer DHM has fram rails that are 1 1/2 wide and like 5 1/2 tall. The 2 diffrent sets of U bolts that came with the jack are to long. Extra threads need to be tapped on to the U bolts or you need to buy some New smaller U bolts to bolt this jack to my thin DHM trailer frame. If you have a Box style trailer frame the stock U bolts that come in with the jack will work perfict. The mount you see in my first picture is of the Stock POS jack. I decided to buy the $20 extra weld on mount and weld the new mount onto the existing trailer jack mount. This way the paint on my trailer should be OK and Ill just have to do a small paint touch up.
12-10-2008, 5:05 PM
grant, i'd prefer not to use the u-bolts. do you know what they call (or part#) for the additional plate? was that specific for DHM? i emailed fulton.
12-10-2008, 5:23 PM
nevermind grant. i found the part# it's 0928061-00. any guess what it would cost a trailer shop to replace the plates?
12-16-2008, 6:09 PM
Hey Here is a Picture of the $20 Weld on jack mount The Part# is on the box. I should get this installed in the next day or 2
12-16-2008, 7:24 PM
G is right on with this jack. I recently replaced my original POS on my VM trailer with one of these. Night and day! I did have to add a few threads to the U-bolts as G stated, clamped it right over the orig. weld on. I didn't know about the weld on adapter bracket, may have to upgrade to that for a cleaner look! Thanks G for the part #
12-17-2008, 5:14 PM
I had a local welding shop install the weld on mount for $30. The jack works awesome.
12-17-2008, 5:29 PM
Yeah man that looks bout it, bout it.
12-18-2008, 10:42 AM
yeah nice and clean. me wants.
