My boat does the same thing...only when I use reverse after turning perfect pass off. However, if I turn the boat off, then on after turning perfect pass off, the throttle response is fine. In my case, it apparently has something to do with how the servo motor winds the throttle cable. If you were turning perfect pass off, maybe this applies to your problem.
