Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2009
Old     (beau4889)      Join Date: Jul 2009       07-28-2009, 9:21 AM Reply
Has anyone ever added sacs to an IO such as a bayliner. I dont usually ride behind it but taking a trip down to shasta and some family has one that I will be ridding behind. I really want to see if I add weight if it increases the wake size with keeping good shape and stays solid. Anyone else ever do this. If so where did you add the weight?
Old     (eubanks01)      Join Date: Jun 2001       07-28-2009, 9:39 AM Reply
I can't speak for your specific boat, but in my experience the best way to run an I/O is to put extra weight in the bow and then trim up the outdrive between 1/4 and 1/2. Trimming the outdrive will clean up the wake and the extra bow weight will conteract the added bow rise from trimming.
Old     (absoluteboarder)      Join Date: Aug 2002       07-28-2009, 9:50 AM Reply
you may not notice much unless you add a lot of weight....and by the sounds you will have a few people in the boat. the ultimate problem is that the boat most likely has a high pitch prop for maximum speed and if you start loading her up you may have problems planing(thats why weight has to be up front)or holding speed. Otherwise what eubanks will be the best short term experiment that will work.
Old     (mikef9844)      Join Date: Sep 2008       07-28-2009, 10:35 AM Reply
my i/o:
1,000 lbs triangle bow sac
150 lbs on each side of engine = 300 lbs rear.
2-4 people in the middle = 300-600 lbs center.
trim up 1/2 - 3/4 and its respectable for an i/o.
its what i got for now and it works well for me.
I also have a 14x18 4 blade prop.
Old     (beau4889)      Join Date: Jul 2009       07-28-2009, 10:37 AM Reply
Well I will have 2 500 pound sacs and a 750 pound sac. So I will have 1750 to add where I want or need. Probably wont fill them all the way up. and I am pretty sure that its pitch on the prop is good for getting out of the hole and getting on plane. Its a bigger bayliner and already throws a decent wake. With some good shape. I usually ride behind an X-star and a malibu. I know it wont really compare But I am curious on how close I can get it to be like those. Thanks for the info guys. If you have any other input let me know. thanks.
Old     (beau4889)      Join Date: Jul 2009       07-28-2009, 10:39 AM Reply
so it sounds like messing with the trim is the key to fine tunning the wake...
Old     (drknute3)      Join Date: Sep 2008       07-28-2009, 10:40 AM Reply
My Cobalt likes weight up front as well. Currently running 1100 up front and 560 in the rear. With a little trim, the wake cleans up nicely. Plenty on wake for me and my crew.
Old     (beau4889)      Join Date: Jul 2009       07-28-2009, 10:53 AM Reply
oh ok. so more weight up front then in back and have the trim up some... sounds like thats going to work best. we will see. every boat is different...
Old     (hockey9)      Join Date: Mar 2009       07-28-2009, 11:42 AM Reply
Like everyone else posted weight is good and some trim use! In a buds old boat which was a Bayliner we just used a 750lb sac and layed it on the floor all the way up to the bow and trimmed around the 3/4 mark.
Old     (beau4889)      Join Date: Jul 2009       07-28-2009, 12:06 PM Reply
How was the wake. Big and solid? Could it compare to V drives?
Old     (bmartin)      Join Date: Jan 2007       07-28-2009, 12:56 PM Reply
Yes, if you trim it correctly you can get a solid wake in a lot of I/Os. Big would be relative, but if it is set up it can be decent. One of the biggest wakes I have ever seen posted was from a cabin cruiser I/O but that is not your typical I/O.
Old     (tchs22)      Join Date: Sep 2005       07-28-2009, 1:00 PM Reply
i have an ebbtide 210 i put 550 in ski locker with a 250lb in each side with a lil trim work......and it cleans up real nicely...and mine compares to some vdrives and the wake is as big or bigger
Old     (lfrider92)      Join Date: Sep 2008       07-28-2009, 2:00 PM Reply
650lbs in the bow, 3 people in the boat, one in the water. trim about 1/4 way up. throws a killer wake. supper firm, clean, and gives pretty good pop
Old     (beau4889)      Join Date: Jul 2009       07-29-2009, 8:07 AM Reply
wow. thanks for all the input. Ya that wake looks great.
Old     (lfrider92)      Join Date: Sep 2008       07-29-2009, 9:06 AM Reply
BTW thats a 22.5 MPH and at 65 feet. the wake looks about the same at 70 feet if you kick it up to 23.5.
for the time being though, im working on a backroll and dont want to worry about clearning both wakes so im riding a little short
Old     (beau4889)      Join Date: Jul 2009       07-29-2009, 11:00 AM Reply
Oh ya. I do that too when I am working on new stuff.
Old     (lfrider92)      Join Date: Sep 2008       07-29-2009, 12:48 PM Reply
i just wanted to let you know.
Old     (jtnz)      Join Date: Sep 2007       07-29-2009, 7:11 PM Reply
I'd put the 500 or the 750 right up front as far as you can get it, the first 500 in behind it and the second 500 across or just in front of the back seat.
Most of the time on our boat we run about 500 up front and nothing in the back, not counting crew. Once the boat gets it's motor back I'm gonna play around with adding some weight to the back.
Old     (beau4889)      Join Date: Jul 2009       07-30-2009, 9:08 AM Reply
Thanks.
