Old     (befox2)      Join Date: Jul 2007       07-27-2007, 12:03 PM Reply
I am looking at a 93 ski nautique. Are these boats with a tower good for Wakeboarding. It has 285 hsp, inboard motor.
Old     (siuski)      Join Date: Feb 2003       07-27-2007, 1:51 PM Reply
I had one for four years. We put a tower on it and plummed in ballast hoses. It puts out a wake similar to the 210, only smaller. It would be a good starter boat for sure. The SN2001 (1982-1989) is better for riding.
Old     (market_open)      Join Date: Apr 2007       07-30-2007, 12:49 AM Reply
I like mine! Weighted and reproped, it makes a nice wake. Take the weight out and it has a world class ski wake. Great crossover boat.
Old     (befox2)      Join Date: Jul 2007       07-30-2007, 9:06 AM Reply
Any other thoughts on this boat. I am seriously considering buying it. Anyone have any issues with this year Ski Nautique? Anything I should check for specifically?
Old     (siuski)      Join Date: Feb 2003       07-30-2007, 9:15 AM Reply
I'd look to see if it has the electronic ignition or has been converted to a distributer. You can't get parts for the electronic ignition if/when it goes bad. It's not a positive or negitive, just be aware. Also look at the dash and circuit breakers. When I got rid of mine, the mounting holes were starting to fail, made the dash real loose. The circuit breakers also fail and are ~$20 a piece. Other than that, do the other common things when looking at a used boat, compression test, water test, etc.
Old     (wakebrdr38)      Join Date: Sep 2006       07-30-2007, 3:01 PM Reply
an ex girlfriend of mine has one...it through a pretty good wake when weighted, however not nearly as good as my 2001 with the same weight
Old     (95sn)      Join Date: Sep 2005       07-31-2007, 11:29 AM Reply
285 HP Pro Boss is a great torquey motor, should have Pro tec ignition w/ coil pacs. 93 was first year without wooden stringers so no dry rot on the 93. It has more room than a 2001. Weighted it will have a good shaped wake, just not as steep as 2001 w/ same weight. Still have a great ski wake w/o weight.
