Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 27, 2003 > Archive through May 13, 2004
Old     (powdrhound)      Join Date: Nov 2002       05-04-2004, 9:18 PM Reply
Any one had any experience with one of these.. hows the wake etc. etc.
Old    caliwakeboarder            05-05-2004, 6:33 AM Reply
I love my 20v. I can load as much weight as i want and the wake never crumbles. It's not as big as other boats but it does the job. 6 people is comfterable. I have had as many as 10 with 1000 lb fat sacks and it was a little tight. The wake was huge though!! I have not had any major problems. It is a good solid boat. It does well in Havasu chop. If you don't need a big boat this will be a great choice.
Old    sandman            05-05-2004, 9:36 AM Reply
The 20V is a great boat but I believe you can step up to the 22V for only about $1500 more.
Old     (powdrhound)      Join Date: Nov 2002       05-06-2004, 4:43 AM Reply
Kyle what other boats di you consider before you bought the 20V and what made you decide to go for it??
Old    caliwakeboarder            05-06-2004, 5:50 AM Reply
Before the 20v i had a 20i. The wake was washed out and steep. I had ridden behind a super air, prostar 190, and a air natique. Then i test drove the 20v with the new hull and i liked the wake a lot. The new hull was not out for the 21v and i did not think i needed the extra room. The 20v has a lot of storage and for 4 to 6 people it is plenty big. So i went with it.
Old     (powdrhound)      Join Date: Nov 2002       05-06-2004, 12:47 PM Reply
whats it like on gas
and what was your opinion of the super air wake and how does it compare in shape to the 20V???
Old     (will5150)      Join Date: Oct 2002       05-07-2004, 8:06 AM Reply
There is a HUGE difference in Wake size and shape between the Tiges and the Nautiques. Nautique has a much lighter and narrower hull- around 92-94 inch beam I recall? The Tige is 102" and outweighs the competition by a minimum of 1000 Lbs.-BEFORE you add ballast! While this can be hard on gas consumption, there is no comparision to the wakes- the Tige is MUCH better- Wider, very crisp but not too steep. You can ride at 75 ft. and it's like being at 85-90 with any other boat. Also, the Tiges have very high freeboard and better seating. In the Nautique you kind of feel like you're riding very high out of the boat. I have kids and I like feeling like they're safe in the boat and the Tige provides that nicely. If you're going to Ski 90% of the time and wakeboard occasionally, then you may want to go with the Nautique- it has a much better skiing hull and wake shape at 32-36mph than the Tige, but we tend to board more these days. Hope this helps.
Old     (akdoc)      Join Date: Feb 2004       05-07-2004, 8:16 AM Reply
The 20V has a beam of 96", the 22 and 24 series have beams of 102". The tige does outweigh most other boats, the 20v is like 3880 pounds, dry.
