Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 30, 2009
Old     (sunnfun)      Join Date: Jun 2009       06-11-2009, 1:30 PM Reply
I'm just getting started in the sport and have been using a friends old board to train on and make sure I liked it. His old board is a 136cm and it works great for me. (I am 6'1" but about 150#.) I found a great deal on a 134cm board, but wasn't sure if it would work for me. After reading a bit online, it appears as though the board will handle my weight bracket, but are there any other things I should consider before buying? Are there advantages to having a shorter or longer board?
Old    dperizzolo            06-11-2009, 1:43 PM Reply
You'll generally get more pop out of a longer board. With your weight, unless the 134 is really wide, I would go about 136 or higher. You will probably just find it a little easier to ride.
Old     (innov8)      Join Date: May 2005       06-11-2009, 2:06 PM Reply
Go bigger, better pop and softer landings, you could ride a 134, but I think you would be happier on a 138, 140 or 141.
Old     (jacob23)      Join Date: Jun 2009       06-11-2009, 2:24 PM Reply
i am also 6'1" and i way about 170 and i first started out on a 135 hyperlight and i thought it was good board until i tried my friend davids 139 lyman and the bigger board definetly made things easier to do. so for your height and weight you should be riding a 139
Old     (andy_nintzel)      Join Date: Sep 2004 Location: Minnesnowda       06-11-2009, 2:40 PM Reply
With your height I would say get at least a 140. Really your going to want to make sure that a shorter board is going to allow you to get a stance that is wide enough to be comfortable.
Old     (rmcronin)      Join Date: Aug 2002       06-11-2009, 4:50 PM Reply
I agree, at least 140. You probably won't lose any weight. A lot of my friends are under 6' and ride 142-144. Bigger board=bigger air and easier landings. As Andy said, the wider stance is also a big consideration.
Old     (jarrod)      Join Date: May 2003       06-11-2009, 5:22 PM Reply
140
Old     (gunnertom4593)      Join Date: Sep 2008       06-11-2009, 5:33 PM Reply
I'm 5'10 145 and ride the witness 140. Bigger is better in my opinion
