Old     (kalcotter)      Join Date: Aug 2004       04-15-2005, 11:49 AM Reply
Has anyone ever patched a hole in their exhaust? I don't think I can afford to replace it right now. (eventhough I probably should) So, I'm wondering how hard it would be to patch it and what to use... I'm thinking duct tape probably wouldn't be the answer... Thanks!
Old     (sbt3)      Join Date: Jun 2002       04-15-2005, 12:56 PM Reply
I would guess that duct tape wouldn't work for too long. I assume the part that is leaking is the fiberglass tube. If that is the case go to walmart spend $10 and get a fiberglass repair kit. You should be able to have it patched up in 20 minutes then let it sit for a day to cure.
Old     (acurtis_ttu)      Join Date: May 2004       04-15-2005, 1:17 PM Reply
I repaired mine with fiberglass its lasted about a year so far
Old     (norcalmalibu)      Join Date: Jun 2004       04-15-2005, 1:54 PM Reply
well if its on the manifold, use JB weld or a muffler sealer. If its leaking out the back get some fiberglass repair.
Old    bigdtx            04-15-2005, 2:04 PM Reply
Those 2 holes at the back are supposed to be there.
Old     (jayc)      Join Date: Sep 2002       04-18-2005, 2:52 AM Reply
JB weld or similar on the manifolds will last a season or two. Glass the tubes at the rear well and they will last for years.
Both repairs under $10 !
