I went to the local scrap yard and bought two 155 lbs blocks of lead that were used in military aircraft as ballast to level the plane. Cost about $.40 per lbs. I wouldn't recommend doing this though. The blocks were 8" X 9" and 10" tall... they were to big to melt down all at one time. I tried cutting them down with a Saws-All but the blade just got gummy and wouldn't cut through them. Ended up having to use a band saw with coolant to keep the blade free of gunk. After I cut them down (about 2.5" X 4" X 4") I used non-stick bread pans on a large gas grill. The bricks melted but it took FOREVER, and pulling 25-27 lbs. of molten lead off a grill at waist height was not fun. I did help speed the process up a bit by using my propane torch that I use when connecting copper plumbing. After they cooled they dropped right out of the bread pans and I coated them with Rubberizer (comes in a spray can at the local home center) because lead doesn't rust but it will oxidize and screw your carpet up. Knowing what I know now and doing a little bit more research... I would have gone to the local gun/ammo supply place and bought 25 lbs. bags of lead shot for reloading target loads. It's like $.45 per lbs that way but much much easier to handle and melt down. Some of the guys on here suggested going to the local tire center and asking them for their old tire weights. The problem with that is the weights are coverd in brake dust and brake fluid and also have little metal clips attached. Talk about some toxic fumes when you open the lid of the grill... not to mention the next time you grill out!! Site Note: I thought LeadHeadz went out of business do to the expenses associated with shipping all that weight.
