Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 26, 2006
Prev Previous Post   Next Post Next
Old     (highdyner)      Join Date: Oct 2006       11-12-2006, 7:59 AM Reply
I have a 1994 PCM 5.8L motor with the Pro Tec electronic ignition (i.e no points or rotor) and carb. The motor has always run great, but the boat didn't get used this season and now it won't start. It cranks fine, but I'm only getting spark at 2 cylinders. Checked the wires, all visible connections, and battery condition. All seem fine. The coil modules look fine as well (no rust or cracks anywhere). Does anyone know more about this ignition system or experienced similar symptoms. I found a kit that replaces the Pro Tec with a normal distributor setup, but I'd rather not spend the money if this is just a bad connection some where. Any and all help is much appreciated. Adam
(Message edited by highdyner on November 12, 2006)
